Old 09/30/2009, 03:11 AM   #1
turborex
turborex's Avatar
turborex is offline
Default differences on turbos
can anyone tell me the difference between journal bearing, wet float bearing, and ball bearing.
i know ball bearing is less lag time even at high a/r and faster spooling i think, any help is appreciated thanks
Old 09/30/2009, 09:44 AM   #2
jordan_xX
jordan_xX's Avatar
jordan_xX is offline
Default Re: differences on turbos
I may be wrong but, I think a jounal bearing turbo is oil cooled only while ball bearing turbos are oil and water cooled.
'97 Type R
(Type Replica)
-Spoon Engine
-T-66 turbo
-Motec Exhaust
-Skunk 2 pistons
Old 09/30/2009, 11:21 PM   #3
turborex
turborex's Avatar
turborex is offline
Originally Posted by jordan_xX View Post
I may be wrong but, I think a jounal bearing turbo is oil cooled only while ball bearing turbos are oil and water cooled. The water makes the turbo spool faster while keeping it cooler.
thanks for your input, ill keep that in mind.
Old 10/01/2009, 02:23 AM   #4
Sleeper91TSI
Sleeper91TSI's Avatar
Sleeper91TSI is offline
Journal bearing can be oil cooled and water/oil cooled,many Mitsubishi turbos are like this.I dont know a lot about the bearings as I am just learning,but I was told that ball bearings cannot be rebuilt,when that $1400 Garrett GT4088R takes a shit,you throw it away.Id rather have a standard jorunal bearing just because it can be rebuilt.
98 GST....Too many parts to list..Tryin to get shit on?
If NISMO is Nissan Motor Performance,HOMO is Honda Motor Performance.
Old 10/01/2009, 06:36 AM   #5
dsmer06
dsmer06's Avatar
dsmer06 is offline
You can rebuild a ball bearing turbo, it is just very expensive.
1992 Galant VR4
2005 92x Aero
2000 2.5 Rs
Old 11/06/2009, 08:40 PM   #6
bitchasscracker
bitchasscracker's Avatar
bitchasscracker is offline
just as expensive than buying a new one ??? lol
turbos are like dicks...... the bigger the better
Old 11/15/2009, 10:58 AM   #7
ej8mando
ej8mando's Avatar
ej8mando is offline
Guess I don't know about a 'wet float' but thrust bearing is going to be similar to the bearings you use for a crankshaft or rods where they're smooth all the way around and the shaft itself floats on a very thin layer of oil to minimze wear. A ball bearing is exactly what it sounds like, it's a bearing with little balls that line all around it.
The ball bearing turbos are known for taking harsher conditions, they require less oil to properly work, and they can improve boost threshold (the amount of time it takes the turbo to spool from lower RPM) and turbo lag (the amount of time it takes the turbo to fully spool after shifts). As far as how reliable they are, I've had thrust bearing turbos that last over 100k miles (stock mitsubishi) and some that have only last less than 5k miles due to improper treatment or even contamination in the oil. Ball bearings are the same way, they will last forever and a day as long as you treat them right.
As far as what you should get, it really depends on the application, sometimes you really don't need a ball bearing turbo. Example of that being you've got a properly sized exhaust A/R, everything is setup properly, the turbo isn't overly large and you're moving a good amount of exhaust, you wont really notice much of a difference between the ball bearing and the thrust bearing. However if you're spinning it pretty quickly or you want as much out of the turbo as possible then ball bearing might be worth the extra cash, or dual ball bearing if you have the option/money; that or if you know you're going a little too large or have specifications a little outside the norm, ball bearing could really help to improve a poor threshold or lag (maybe 400-500rpm threshold difference).
If you're serious about doing this, I've always found the best thing to do is to call up the turbo manufacturer as they understand their flow rates better than what I ever could and they will make a good recommendation based on your power goals and where you want your power range to be. The last thing you want is a turbo that's too large or small and all your power to come on as your shifting or straight off idle.
[SIGPIC][/SIGPIC] this is how u get free food at a white resturant!!!!
red ej8-SOLD!!!
em1-daily grind;)
Old 11/15/2009, 06:55 PM   #8
heeltoehonda
heeltoehonda's Avatar
heeltoehonda is offline
^^ good info
Old 11/17/2009, 01:32 AM   #9
b20zDA
b20zDA's Avatar
b20zDA is offline
he went with ball bearing!!!
